A7V8X-X Possible To Flash Via CD?
3 Dec 2004
Hi all,
Ive purchaded a cheap 2nd rig(A7V8X-X 2700+)
I want to upgrade the bios but I do not have a floppy. Ive tried to use winflash but it does not look like its supported.
Is it possible to do it via cd or another method?
Thanks
Ice Rich said:
Hi all,
Thanks
Make a dos bootcd + include the flashimage .rom onto it + the dos flash util
Boot with cd
Flash in Dos
Done...
Thanks very much for reply.
Ive done a big search on google but I am still really confused.
Can you give a more detailed explanation of what I need todo?
Would be very much appriciated.
Thanks
I think I now have the correct bios + app. I just need to know how to burn (settings) + what to type in DOS.
Thanks
I just created a boot cd with my bios + aflash.exe.
When I boot from cd and get to the commanded prompt I change the a: to d: and type aflash.exe but get the error 'insufficent memory'?
Any suggestions?
Thanks
Any suggestions?
Thanks
Never heard of that, what version of dos gave you tried, try microsofts one.
Also i dont know about your mainboard but newer boards also have the option to flash in bios, you press alt-f2 (if i renember correctly) in the main boot screen and then it starts a flash utility searching floppy's and cd's for .rom files...
Thanks for reply,
When you say dos version - how can I find out?
I just copied this file:
http://www.bios-drivers.com/drivers/83/83837.htm
+ the latest bios onto cd.
Also, I did try the alt+f2 method but it only looks at the A: (floppy) drive :(
Thanks,
The prob making a bootable CD for doing this is we don't all use the same burning software.
Try this to make bootable CD :)
Thanks,
Just creadted a cd using that guide but now i am getting the error cannot find bios hook? I typed aflash.exe after booting from cd.
Any suggestions?
Thanks
Go here find board.
Model: A7V8X-X
Aflash V2.21 Utility to update the motherboard flash BIOS - (DOS)
Right click...Save target as........ <that's it
aflash221 (make sure you unzip it before making CD.
