A8-7600 not fm2+
some one might have pulled a switchy.
See it a lot on a certain website who don't quibble about returns, nor check them properly.
The rainforest. Not a reseller either.
I knew it.
I've seen loads of complaints in the reviews stating they opened the box and found the wrong CPU in there.
I doubt highly that it's AMD, as that website takes returns and then sells them again.
Had a couple of dodgy items from their 'warehouse' thing, and their prices have shot up too so I just go new now.
how would you tell a fake from a switchy?
Well, Your cpu, according to the code printed on the front, is supposed to be an fm2 kaveri - it can't be if it has an am3 pin layout; the pins on the back dont match the code on the front. Screams fake to me, unless AMD made an am3 kaveri that we dont know about (and for some reason used the same code as the fm2 version)
I knew it.
Me too, bought a 4690k last week. Turned out to be a Pentium G series! Decided to buy new instead at it was only a £10 difference and it has gone up by £25. Didn't bother buying another one in the end.
Good thing they have a good returns policy.
