I have a single 6950 that manages everything in ultra with 4x AA and it runs perfect. I'm sure a pair of 6950's would have no issue unless your running a crazy res. Are you feeding them enough juice ?
what fps are you getting???
What exactly do you mean by perfect? All cards take a major impact with 4xMSAA - it's an engine limitation, something to do with the deffered lighting system the game uses (other games using this type of lighting have this problem with AA).
On my 580, playing on packed 64 man servers at 1920x1080 with ultra settings, but defferred AA disabled, I get over 60 fps most of the time. With 4xMSAA enabled, the fps drops below 50 fps quite frequently. It's easily playable, but not what I'd call perfect, especially in multiplayer where every fps counts. Plus, post-processing AA at high is good enough that I don't think proper MSAA is needed in this game, unless you like stopping randomly mid game to look at your pixels.![]()
This is the settings I have 4x msaa or whatever is the highest I can go.. At these settings it is lovely and smooth no slowdown and multiplayer runs fine even 64 player maps...
Ok just quickly tried Fraps and it seems to jump around the 45-65fps mark and drops to 30-32fps when some big bangs go off..
that is good going.
whats the rest of your setup???
MOOGLEYS, try playing with vsync off, deffered AA disabled and motion blur switched off - helped boost my kill counts considerably and I didn't really notice any major loss in image quality.
@Moogleys, I have tried BF3 on a single 6950>70 with everything on ultra@1080p and felt pretty much the same, I was surprised myself that it's very playable indeed.
@op, your 6950's in CrossFire should play BF3 on ultra@1080p no problems, what res are you playing at and what's the rest of your specs?
On 1080p 6950 CrossFire, everything on Ultra +4xMSAA, smooth as butter and it doesn't go below 60fps at all for me running on this setup:
Amd 6950>70 Crossfire
2500K@ 4.5GHz
MSI Z68A-GD55-G3
16GB Corsair Vengeance Red 1866 Mhz(Windows Pagefile is disabled)
128GB Crucial M4-Windows
120GB Corsair Force 3-BF3
You Nvidia guys need 2GB Vram..![]()
humm..
Performance Analysis: Battlefield 3
http://translate.google.co.uk/trans...artikel/14650-prestandaanalys-battlefield-3/1
