AAARgh! Help!
15 Feb 2009
OK I think I need some help with a virus.
Story is, I have a WinXP sp3 machine which I use for normal web browsing & more work type stuff. This morning, I was on Face book and a music forum I am normally on and I got a Virus warning from Avast. It was a Trojan in some file in Windows system folder. Well, every time I told it to delete it it popped back up again. Eventually, I opened AVAST, which ran its memory check and told me that there was something running in memory and needed a restart to do a boottime check. I did this, but on restart my DVD drive had vanished.
At this point , I had to go to work so shut down, but tonight I have tried again, the DVD is still missing and theres a SVChost constantly running at like 99% and the PC is running sluggish. So I figure that whatever I got is now resident. So, I shut down, and connected the boot drive up to the PC I am now using, a Win7 PC. This PC was not powered up at any time that the other PC was. I did a virus scan and it found win32:Malware-gen in the Windows\temp folder in a file called ~tm33.tmp. I had it delete that but when I booted the XP machine up it still has the 99% svchost running. I rebooted the XP machine in diagnostic mode using msconfig, the SVChost is not there now so, with the machine unplugged from the router, I started an avast scan running and rebooted my Win7 machine which I'm using now.
So can anyone else recommend any other tools I can use to try to diagnose and hopefully clear my XP machine? And where has my DVD drive gone? Any advice would be helpful!!!
Lee.
OK Malwarebytes hung on a registry key concerning the DVD-rom drive, this must be something that the malware has done.
Combofix seems to have worked, the 99%er is gone and net speed is back to normal.
I got the DVD-rom back by uninstalling it then scanning for hardware - but I'm getting an ElBycheck error - something about a filter driver not being installed.
Any idea how to reinstall ElBycheck? Does it come with one of the DVD region killers (I flashed the firmware like four years ago and forgot what i did!)
I think (but not certain) that Elby is part of CloneCD. You could try re-installing that, assuming you have it installed of course.
