Hi Bear,
Had my HTPC kit for 2 days.
Antec Fusion Case black 430v
Abit AN M2HD MB
AMD Athlon 64 X2 460
Corsair 2GB DDR2 XMS2 twin x
SATA Maxtor 9 200GB
Onboard Geforce 7 graphics
Onboard 7.1 HD audio
DVD R/RW IDE drive.
I have built many systems over the years, never had the issues that we share with this MB.
With this MB, I have not had any issues setting/checking the bios, unit stays on all the time.
Had problems trying to install Media 2005, the unit kept powering down part way into the install.
Re formated HD tried to install XP Pro (only as a check) same problems as Media 2005.
Re formated HD finally installed Vista Ultimate, only after several power downs.
Now like you I cannot cold boot, I get the same message but it will boot after pressing the reset button.
I note in the manual that Abit must have some issues with this MB as the "Troubleshooting" has several comments on booting and power off.
My next task is to update the bios to v17 (m628a17) and see what this does.
Also critically examine the bios settings as they are all on default/auto.
My thoughts are that as the unit stays on when in the bios and only powers down/will not boot, while working the CPU, memory etc. I will then try my memory that in my Asus P5N-E-SLI system.
I will update as necessary.
Not a happy bunny at present
Have you had any success yet?
Any one else had had issues with this MB?
Any one else had no issues with this MB?
Thanks for any comments
Cheers TeeJay
