Can someone please advise me on what settings I should be shooting for with the hardware that I have.
e6600 w/ ACF7
AWD9 Max
Corsair PC2 6400 2x1gb
BFG 8800GTX
BFG 1000w psu
Basically everything you see in this link
http://www.overclockers.co.uk/showproduct.php?prodid=FS-032-OK&groupid=43&catid=781&subcat=
I received the system yesterday overclocked slightly (just under 3ghz) from OCUK (thanks guys), I have since played around with the bios a bit to get to a speed of 3238ghz
I have it set as follows
fsb 360
Multi 9x
strap 1066
Dram SPD (4:5)
5-5-5-15
Core volt 1.41
Dram volt 1.85
MCH 1.52
Idle temp is around 35c
Load temp is hitting 51-52c
If I go higher on the fsb (365) I get a bsod.
What, if anything, am I missing as far as my settings. Is there anything I should be setting/manipulating in the bios so I can go a bit higher ?
Many thanks
e6600 w/ ACF7
AWD9 Max
BFG 8800GTX
BFG 1000w psu
![Smile :) :)](/styles/default/xenforo/vbSmilies/Normal/smile.gif)
fsb 360
Multi 9x
strap 1066
Dram SPD (4:5)
5-5-5-15
Core volt 1.41
Dram volt 1.85
MCH 1.52
Many thanks
