Abit IP35 Pro CPU temp 170c?!
int
int
14 Apr 2008
Exeter
A plethora of problems for me on this new build!
Any who, my Abit IP35 board is detecting my CPU temp as 170c, which I'm fairly sure is wrong, as I can't feel an abnormal temp with my hand and the zalman fan I've got is running full tilt.
Any ideas what's going on here?
The computer would have shut down long ago if it was heading next that temp.
Which software is giving the reading.
This is the temperature in the bios.
I've managed to have it running for an hour or so whilst installing OS and programs, went into the bios to just turn on the alarms for the temp and noticed how high it was!
uGuru doesn't want to show me any temperatures...
Download Core Temp and see what it says. Sounds like it's either a dodgy BIOS reading or a dodgy sensor.
Okay, cheers. I've turned the beeps off for the mean time, doing my head it ;)
Will edit this post with the temps Core Temp gives me.
e: Here's what Core Temp is giving me:
Tj. Max 105
Core #0 41
Core #1 35
Those seem reasonable compared to the values I'm getting from the bios.
I'm guessing your CPU is one of the new 45nm ones? If so there's a number of known temperature issues with these new CPUs.
My E8400 on an Abit IP35 Pro recorded 244 degrees in BIOS.
See here: http://forums.overclockers.co.uk/showthread.php?t=17841158
I just turned off the beeps and also the shutdown due to overheating option.
But there are plenty of other people with other temperature related problems. Just do a search for E8400 temps in the CPU section to see what I mean!
In fact, there has been a new temperature monitoring program developed specifically becuase of these problems. It's called RealTemp and seems to give more accurate readings than any other program out there at the moment.
Read about it and download it here:
http://www.xtremesystems.org/forums/showthread.php?t=179044
Regardless if his cpu is a new 45nm chip, you'll need to update the bios, iirc betabios 16 from abits website fixed the temps on my ip35pro.
You don't *need* to update the BIOS... on my setup and one other identical one I built for my bro at the same time, it worked perfectly out of the box except for the temp issue. Turn off the temp alarm and everything is fine.
I've also heard that the temp problem is not definitly fixed with the newer BIOSs. I am haven't tried any beta BIOSs, but I'm on the latest official one (16 final) and the temp problem in BIOS has... changed!. Now fluctuates between 170 odd and 3 or 4 randomly!
It's worth pointing out that my E8400 has been running at 3.6 GHz 24 hrs prime stable for the last month or so, but then I had the same stable overclock before I updated the BIOS as well.
Ah, I'm running an E8400 in my IP35 too ;)
I did do a little reading last night and it seems the v.14 BIOS has a problem with the temperature.
I'll flash the BIOS later! If I do this, can I use a USB stick rather than a floppy? Believe it or not, I don't actually own any floppy disks or know anyone that has one!
Cheers guys :)
Excellent! Thanks very much.
e: Found my USB stick isn't recognised but managed to get hold of a floppy disk.
However, after creating a boot disk, there isn't enough room to copy over the BIOS files :/
Am I doing something wrong here?
Not recognised in Windows or in BIOS?
If it's in BIOS, then be sure to set it as the top bootable hard drive.
As far as the floppy disks go, you'll need one disk to boot from and another with the bios files on. After you've booted, you can take the boot floppy out and stick the one with the bios on in and update from that.
*smacks forehead*
Thank you :D
Figured I'd bump this one rather than making a new thread.
I've updated the BIOS to the latest version, and I think the problem has just reversed, with uguru giving me temp readings that are too low.
The auto-adjusting of the CPU fan won't kick in when under load, as that uguru value doesn't seem to change under load. However I don't want to run the CPU fan at full tilt 24/7 because I like a quiet room :p
Any idea if there are any programs that can take over uGuru's job with correct readings?
