Built a new system here using the Meg Ace and a 10900k.
First thing I did was turn off the ability for the motherboard to pre-overclock anything, and just enable XMP for my Corsair RGB 3600mhz CL18 ram (2x32gb in slot 2,4)
All seemed like it was running ok and then the RGB randomly turned off my Lian-Lia fans etc which were working perfectly previously, from the next reboot onwards everything went to crap basically.
Now dropping into BIOS sees the bios corrupt, and the actual bios display incorrectly scaled against my screen, and other weirdness like Chinese looking symbols appearing when you enter some aspects of the menu (EN Is selected top right), generally its all fubar, not right at all, also my fan speeds are randomly uncontrolled despite overriding them with a curve and other general weirdness.
Obviously I have reset the bios to defaults with the clear CMOS option, no difference, even gone to the effort of removing the battery from the board for 10mins to make sure it reset, still no difference, as an absolute last resort I have successfully flashed the bios with the latest version from MSI, still no difference.
The board runs and goes into windows no big issue, but is unstable, even having used the dragon software in an attempt to make things how I want.
Basically cheesed off here, expensive board and it seems fubar, actually hating the bios even when it worked if I am honest.
Been building systems since the 90's and never had such nonsense before, but accept I might have missed or done something wrong "maybe", getting ready to RMA it to be honest, big problem is what do I replace it with??? If I was to ask Overclockers to replace it , nothing in stock.....and I really need the 3x M2's slots tbh, I use my PC for work and getting pretty desperate here, beyond desperate actually.
