A quick question, normally when you switch/turn ignition on on your car, the ABS light comes on and then goes off. I had a problem with the ABS light before, the garage I took it to, changed some sensors (ABS ring, speed sensor etc).
They also did a software update on the car now the ABS light does not come on when you start the car/ turn ignition. They said that with the new software update the abs light only comes on if there is a problem. Is this correct I thought all cars with ABS the light comes on when you switch on the car and then goes off?
The car in question is a Mini 1.6 One 2003 model
Thanks in advance.
Thanks in advance.
