Absolute nightmare - spec help required
13 Jun 2026
wales
Evening all,
Long story short had a disaster of day and my PC is bricked (also cant access my old account on here although probably several years since i last posted)
anyways looking to grab some new parts
Currently looking at the bundle offer
I was looking to get the MSI MAG B850 TOMAHAWK motherboard and a new power supply to go along with it.
Im hoping my 3070 isnt dead and wanting to get it all in my Antec P280 case.
My monitor is a 27" Dell S2721DGF, not looking to change it.
Does this sound OK? any suggestions on a decent PSU and possibly a different motherboard as the MAG is out of stock.
Might be tempted with a new case, really liked my old Antec P280. No windows and flashy LEDS please, like an enclosed system.
Many thanks.
Please give this a read and use the provided template, post it in this thread:
Building myself.
Sorry, should have made my post clearer
Need a cpu
Motherboard
Ram
Cooler
Power supply
Maybe a case XL ATX, Preference of no window.
budget under £1500
Looking at either the 9850 or 9800 cpu.
Tend to try and build my pcs for as much future proofing as possible.
Looking to purchase asap
Appreciate your time, any suggestions on a different board as it looks like that one is currently out of stock or is it worth waiting a little bit.
the tomahawk is one of the best b850 boards available. it is available elsewhere too :)
if you desperately only want to give ocuk your money then there are alternatives
ps: there's two different versions, the vanilla tomahawk and the tomahawk max. the max is a higher-end version and also more expensive, you don't need to spend that much (i specced the vanilla b850 tomahawk)
Asus TUF B850-Plus has a similarly well performing VRM to the Tomahawk and the discount for the bundle gives you ~£30 off.
