Ok. I wanted to install windows on my SATA drive. It did, but it kepts setting the SYSTEM (ie, ntlbootloader) on my PATA drives. In a random partition.
I decided to go back to installing windows back on my PATA drive. Only I had transferred all my data onto the PATA drive. However to boot into Windows I had to disable my Primary PATA drive in the BIOS. Windows recognises it, but only as multi-word DMA2. (3.2Mbs)
Anyway, I was using Acronis Disk Director to move the partition so I ould install windows again.... BAD MOVE... Just as I clicked commit I released it would have been quicker to install on the small partition, then move the data, and then move the delete the whole disk.... I hoped Acronis would reboot to commit the action in DOS mode.
It didnt. Now its going to take 5 hours for Acronis to move the partition in Windows. I guess that teaches me... Im using my G/Friends laptop at the moment.
Does anyone know why my SATA disk kept putting the System Files (all 4 of them) on a different partition????
Life is ****
I am a pathetic p r i c k
Life is ****
but only quick format, do not delete partition.
