nopethey arent cracked are they?
from the inverter it as a (4pin MolexDuo male+female passthru power connector) but that connector was broken off so i put a new one on, then i connected 12v a molex plug (like the one u put the hdd/Optical Drive to power them) into the 4pin MolexDuo male+female connector..It uses a converter to AC (I think . . ) If only one side is plugged in then you only get light in the first couple of inches. Try swopping the tubes around / replugging them. You have connected the plug to +12v and 0v havent you?
Length : 300mm
- Voltage : 570 ± 40V
- Current : 3.5 mA
- Brightness : Over 20,000 ± 10% cd/m2
- Lifetime : Over 15,000 hours
- Input voltage : DC 12V (via 4pin molex connector)
- Output current : 2 outputs of 5mA each from inverter
- Advanced silent dual-driver inverter (with overheat protection / 4pin MolexDuo male+female passthru power connector)
when i opened the packaging the connector was broken off the wire...i couldn't see the point sending it back just because the plug was off. but now the lights are faulty.So the connector came borked? If I was you I would have sent it back then rather than bodged it. If it still looks legit to the naked eye, send it back and don't tell them.![]()
. so now im confused why it don't work on my main system. my psu powers everything fine, the 12v line is running at the right voltage and the watts im using at full load is about 400w so its well under 900w so i know it's not a psu fault. i can't see whats the problem.
