I haven't read all of this thread but here's what Stephen Mead, assistant chief examiner at the Institute of Advanced Motorists, reckons you should do in that situation (at the bottom of the article)
ZG002 said:He said on the audio interview that the police told him to keep on the a1... but surely they knew a roundabout was approaching... would the motorway M1 (i belive.. ) not of been a better option..
Enfield said:When you're faced with a situation where you think you're going to die i'm quite sure that your logical side goes straight out of window.
NathanE said:PAS is only for at slow speeds. At the speeds he was doing he could have just turned the ignition off.... What an idiot.
Also the brakes would still work without the servo, you'd just need to use both feet and your body weight.
Clarkey said:what was unpredictable about the situation? if he left the engine running he would carry on speeding uncontrollably, if he turned the engine off he would be able to stop without drama. Seems pretty clear cut to me.
Clarkey said:its hardly unpredicable. I would be able to predict that with failed brakes, nothing would happen if i pressed the brake pedal. Anyway, how is it possibly a better idea to speed along at 130 with no brakes then to shut the engine off and slow down?
bobbyboy uk said:This guy is on fern and philip, ie this morning, this minute !
hmm seems a bit of a pudding.
agw_01 said:Just reading that link at the top of the page, where it says to change to neutral.
Surely the car would slow down faster if it was left in gear.
