Glad you've confirmed my long held (but never verified) belief that audit is tedious...I started out working in the audit department, then got a transfer to tax. Where I'm a lot less bored.
[TW]Fox;17138889 said:I think I'd probably prefer to work for a smaller, regional firm.
Ok, your original comment was bizarre and made no mention of exemptions.
What I mean is, if you have no degree you do AAT first. If you have a degree then in my experience employers will take you on to do AC(C)A straight away regardless whether it's accountancy based.
Again I'm confused (I intentionally removed the reference to the ACCA as I don't know). I was saying the foundation of the AAT isn't compulsory. I think we're both getting confused over what the other is saying.
Oh, and if it helps, the AAT gives 5 exemptions and 1 partial exemption from the ACA depending on which exams you take at the Technician level.
That is because I was repying specifically to a question asked by Dimi about the ACCA recognising the AAT. If you had read the post in the correct context you would have seen that I stated that with a relevent degree he could go directly to the ACCA.
I also stated that the AAT would give him exemptions from the ACCA. To get exemptions to any modules on the ACCA the degree must be an approved one, any old degree will not give you exemption.
Any degree will get you accepted onto a training program, but not all will exempt exams.
We were not talking about the foundation levels of the AAT at all, but the exemptions the AAT would give you in the ACCA.![]()
[TW]Fox;17138871 said:What sort of salary do you get whilst training? I imagine I'd need to take a pay cut. Probably worth it in the long run though.
Blimey, really feel like I'm arguing with you here
I agree, if industry do ACCA, if practice ACA.
However, unless the company you go to makes you do AAT, DO NOT DO IT! It is absolutely not necessary and is not that useful in the longer term.
That is what I'm disputing. In my experience it's ANY degree (not just accountancy related) that will get you straight into AC(C)A in general. We have some guy who did politics who started straight into ACA.
Although given the current climate, a finance degree would be preferable.
I also found that with my own career my Maths/Economics degree pushed open a few doors a little quicker than they would have otherwise.
Susie.
Screw that, do Tax. Far more interesting.![]()
[TW]Fox;17138164 said:Because its cheaper and he's less likely to run off to a better paid job after the training.
Yep!
Just waiting on a letter confirming my full membership in the CIOT - get in.
what kind of tax do you specialise in?
At the moment on the training programme I'm on there's support for ACCA/CIMA/CIPFA and I think that overall ability and opportunities offered are likely to have more bearing on career progression than what qualification you've got - at least that's how it looks from the bottom now, this may change if/when I get a bit higher up and find
I'm limited by my early choices.
You sure thats the case even for mature students?
As i was thinking of taking up a career development loan to fund mine.
Not sure... I think it might be only for under 21s or something.
Either way, they're really pushing it at the moment.
