Hi there,
I am looking for a new monitor, currently I have a 17" sharp LL172GB which for the record has been excellent, but its time for something bigger.
From the title of the thread, you probably know which ones im considering.
NEC MultiSync® LCD20WGX2
For a few months I had been certain that when I had saved up enough money, this would be my firm choice, it has some pretty nice specs and unit itself is quite good looking. The only thing that bothers me is the coating on the screen, it will be place directly facing a window (about 5m away) and im concerned that the glare might be too much.
Acer AL2216W
Then this monitor came out and changed my mind a little, its obviously quite a bit bigger than the NEC and is a whole £100 cheaper, the specs are very similar and it now seems like the obvious choice. The only thing that worries me about this monitor is its lack of Dvi input, my graphics card is dual Dvi, and I have always used Dvi, just wondering if there will be any noticable decrease in quality using Dsub.
These are the two I have narrowed it down to, im pretty stuck here so any help would be greatfully recieved.
Cheers
Acer AL2216W
Cheers
