- 7 Oct 2008
Hi all,
Previously had an AOC Q3279VWF 75hz Freesync monitor but it felt terrible for gaming so just received an Acer KG271B 240hz FHD Freesync monitor.
Monitor feels great when gaming, but the problem is that I keep getting random black screen flickering :/
Sometimes happens very often, sometimes not for a long while but happens every single day and its annoying the hell out of me...
The black screen flickering seems to be worse when connecting this monitor up via HDMI 2.0 than DP 1.2, but still flickers on both ports. I've tried various quality cables and lengths of each type but the issue still occurs no matter what I try.
I've done the usual DDU, remove OC's etc. but made no difference...
I hooked the same monitor up to my laptop via hdmi and did not experience any flickering...
i hook my old monitor up and everything works fine...
Makes no sense, im wondering if this is some sort of driver issue between the RX 580 and the Acer KG271B?
Anyone else using the same combination? Let me know if you have any similar issues, or no issues at all!
