- 8 Jan 2011
- London, UK
Hi all, I can’t enable 120hz on my cg437kp monitor. I am running:
supplied DisplayPort cable
win7 64bit
dual 980 gtx Nvidia in sli
dual monitor (cg437kp primary, 43inch + Philips BDM4065UC secondary, 40inch)
if I try to run only one monitor, it’s the same issue. I have the latest Nvidia drivers installed. I have tried enabling and disabling adaptive sync.
I can’t seem to make it work.
I think I might have a possible reason for what the issue might be. According to the 980 gtx card specs, display port 1.2 is what it supports. Which I assume means it’s not able to support display port 1.4 which is what this monitor may rely on to run at 120hz.
However, reading up on DisplayPort 1.2 specs, this says 120hz is possible at the 3840x2160 resolution under dp1.2. So not sure whether this is actually the issue or not.
Does anyone have experience with this or able to advise? Thanks!
win7 64bit
