ACHI mode
13 Dec 2003
UK
Hi there
im about to install windows on a drive and want to try the achi mode
to enable ncq etc
ive got another drive whichh was used as a normal sata mode (infact sata as ide in bios)
now with the main the drive being in achi mode, will i be able to access the
second drive as normal in windows or do i have to format it before i can use
that in achi mode too? (ive got valuable data on there :( )
thanks
hmm just given it a try, installed ACHI sata drivers on the main OS drive (installed windows)
plugged in the 2nd drive in the same sata chipset and it works all fine (all data is accessible) :eek: :)
