acrobat help
^^ Lol to the above.
I believe acrobat pro allows you to manipulate documents, that the normal acrobat (reader) doesnt.
To the "troller" : Acrobat Pro also has an OCR feature. Allowing you to convert a pdf file to text (Word etc).
nothing like watching newbies fight to the death.
pdftoword.com is good, worked well for me the other day.
Ash for images you can use the select tool or the snapshot tool in acrobat reader as well. Not sure how good the quality will be for printing though.
Press the PRINTSCRN button (Next to Scroll Lock).
This copies the image on screen to the clipboard.
Paste it into an image editor (Photoshop / Paint)
Save it as a picture file..
Note: Pressing ALT + PRINT SCRN only takes a screen shot of the active window*
(So if you have IE open, in the middle of the monitor then it will just take as screenshot of that window, and NOT the whole screen)
