Acrylic- best cutting tool
28 Jan 2015
Client has asked me to replace her flexi tubing for acrylic not petg and not used it before. Whats best way and tools to use for this? I have Barrow cutter that I use for petg but not sure it will work
I found a hack saw to be the best thing to cut it.
A copper pipe cutter will work but you have to be careful not to crack the tube with too much pressure.
Hack saw and deburring tool is your best bet/
Don't even try with you petg cutters it will just shatter the acrylic.
He’s mentioned using PETG which you are not gonna shatter, I’ve tried with a hammer and it’s tough stuff :D
I just use a hacksaw, tiny mitre block and tube deburrer.
Wrap the area you want to cut with a bit of masking tape, mark where you want to cut, hacksaw a tiny bit away from your mark in the mitre block so you have a nice straight cut, use the debur tool to clean up the inside and outside edges to get the chamfer (which is why you cut a tiny bit away from your mark) and then a fine grit sandpaper just to take any roughness off the chamfer.
