A decent anti-virus on it's own will cover you for malware/adware anyway (e.g. ESET NOD32), so no need for either.
Windows 7 comes with Windows Defender enabled by default which will help protect against malware/spyware if you want the extra protection.
A decent anti-virus and some common sense and you'll never get infected.
] scan with Malwarebytes and maybe once every 3 or 4 weeks do a quick scan with Windows Defender. NOD32 I just leave to do its own scheduled scans.Hi All do u need both Ad-Aware and Spybot free software on windows 7 ? or is just one enough if so which is best ? thanks![]()
I would consider dropping both and replacing them with MalwareBytes.
A good AV and MalwareBytes should be enough if you Browse smart etc
There is no harm in running more than one as no one product is guaranteed to spot every piece of malware.
Personally I do a regular [ish] scan with Malwarebytes and maybe once every 3 or 4 weeks do a quick scan with Windows Defender. NOD32 I just leave to do its own scheduled scans.
Personally have been using MS security essentials, not had a single problem.
Yep. Avast has malware/spyware definitions as well so you may as well disable Defender, unless you're a bit paranoid.
As said above, common sense and a decent anti-virus (Avast is decent) will be more than enough.
So do you switch of both real-time protection and auto scan.?![]()
I dumped it when it started needing a service to run.AD-Aware has turned into a piece of slow bloatware, don’t bother with it.
