Ada-ware removal problems
6 Dec 2006
Barnsley
I have just installed a n ada-ware removal program for Lavisoft 1.6r pro.
My system has been running fine for months with out any problems. I run the program and removed all the highlighted bugs. System keep slocking up now.
What I want to know is does any ada-ware software remove componants from the opperating system and is there a better program so when I run it it just gets shut of the rubis and does not affect my pc stability?
hmmm, well I've been fine using the program, maybe your pc was so messed up with spyware that it damaged part of the system files when it was removed, probably not adaware's fault entirely in that case.
Spybot Search and Destroy has a 'resident' application that protects the registry from stuff, so try that.
Thanks for the reply.
Will give that ago. Dont think it was any thing that rung a bell, was approx 40 items that it removed so would not call that exesive.
But thanks for the software reply.
I forgot to mention you have to enable the 'resident' from within the spybot program, I don't think it is automatically on.
try spybot S&D
ad aware may have removed a bit of spyware that had embedded itself in your system and caused a conflict or somthing.
