Adaptec 4805SAS help needed
5 Jun 2006
Singapore
hi guys, i need some help with my Adaptec 4805SAS controller card.
I've already got Windows XP installed and i added the Adaptec 4805SAS card to the system. I installed the drivers in windows.
Afterwhich, i initialised an HP OEM Seagate Savvio drive and created an array and formatted it.
Then, i reboot and after the verifying DMI pool data screen, it just hangs there with a black screen.
can anyone help!!! thanks
People who have cards as funky as that don't deserve help :mad:
Just kidding!
Sounds like it's hanging at the point where the Adaptec BIOS should come up. I assume from the fact that you've installed the drivers for the card in XP that the system boots with no drives attached to the card?
yup.. i installed the drivers for the card in XP and it manages to boot without the SAS hdd..
anyway, i think i'm going to flash the firmware later.
okay, i've flashed the Adaptec card to the lastest firmware. I've also updated my motherboard (AOpen i915Ga-HFS) to the last firmware. But it keeps failing to boot into windows. It keeps hanging with a black screen just before the Windows XP screen with the scrolling bars.
I tried something rather dangerous by booting into windows without the SAS hdd and plug it in when i'm in Windows. This only works when I have created an array in the Adaptec BIOS and then remove the hdd before booting up. In the Adaptec Storage Manager, it'll be detected as a logical drive.
If i do not create an array in the Adaptec BIOS, the SAS drive will only appear as a hotspare in Adaptec Storage Manager
I think you need to try and work out if it's getting as far as starting to boot Windows - there's a wee text mode bit of the boot process going on before the XP logo comes up.
Have you tried safe mode?
hmm.. i've not tried safe mode though..
but its very irritating that its not working!!
anyway, some benchmarks i did on the HP-branded Seagate Savvio 10k.1 36gb
with Adaptec 4805SAS
with LSI 8408E
