- 8 Jan 2020
I am running a custom loop consisting of the EK kit P360. https://www.ekwb.com/shop/ek-kit-p360 which has a single 360x38mm radiator. I have a Ryzen 3900X and EVGA RTX 2080 Ti in the loop in the sequence of pump/reservoir to GPU to CPU then to radiator and back to pump/resevoir. After an hour of overclocked GPU stress testing I am seeing GPU temps of 48-51c and CPU temps of 45-50c so both around the same. I am thinking of adding a second radiator (the same as that which is fitted) between the GPU and CPU. Will this be a waste of money? What kind of temperature drops can I expect to see? Thanks.
