adding a drain port to a loop
4 Oct 2005
Herefordshire
Hey guys I am after some more advice .
As mentioned in my previous posts, I am doing (or trying) to build a sort of no compromise wc loop to cool my system. and I want to do it correct. previous attempts I have always scrimped and saved where I can. but not this time I want to do it properly.
Now as the title says I have never added a easy method of draining/filling.
Co can you recommend me some fittings ect so I can add a drian system to my custom loop please.
Also a fillport(this will be inside the case as apposed to one that you drill a hole in your case for)
tubing il be using
Primochill Primoflex Advanced Tubing 19/13 - Clear
the fillport need to connect to the top of a EK Water Blocks EK-RES X3 250 Reservoir. or do you think I can mange without a fillport ?
thank you in advance.
What rads do you have? I drain my system by removing the g1/4 stopper at the bottom of my front rad
The way I did it was to add a koolance quick disconnect into my loop
ive got another quick disconnect that does onto a spare length of hose
when i need to drain my loop i disconnect the two in the main loop and connect it to the short length of hose and drain into a bottle/bowl
