Adding/Changing LED on fans.
  • Thread starter Thread starter nlr
  • Start date Start date
nlr
nlr
30 Jul 2010
I was wondering how do you add/change LED'S on case fans and I would appreciate it if someone could explain/show me in detail.
Regards,
Nick
Never owned an LED fan, so I might be wrong, but why not have a look and see how the LED's are attached to the fan, remove them, and then try to add the new ones in the same way?
Iirc they are usually just secured with a dab of glue so should be easy enough to get the old ones out. Then just solder new ones onto the existing wires and re-glue. Should hopfully be that simple.
ent they just clear. wudnt it work if u just painting some nail varnish one them with the colour you want. I know people that do that with there car head light bulbs
It can be done, although if your soldering skills are non-existant, it may be wise either to not bother as it is very fiddly, or go ahead and practise on a different fan first.
LED's can only go one way around. There is a flat on one side to tell you which wire is the cathode (- / negative ).
id just go with my idea. get some colour nail varnish you want. and then paint the led's that colour. they just pop out anyway.
What about this?
12 Orange LEDs on a black Tri-cool fan. I drilled some holes and wired up 4 circuits of 3 LEDs each.
Here's a red fan I rewired to become a white fan, it's not using holes or anything, just tape to hold them. I don't like the fan very much so it was just a test.
Rewiring a fan is easy.
Red LEDs (1.8-2.0v) have a different voltage requirement than blue LEDs (3.2-3.8v) (if they are blue, I'm assuming) so you may find that they will be overbright and possibly even pop. You may need to add in a resistor. How the existing circuit works depends on how you would do the mod.
If the LEDs are positioned in the corners and wired independently of each other it's just a matter of removing them from their hole, cutting off the LED, stripping the wires, positioning the new LED (poss with a 56 ohm resistor on the Anode), hot glueing, wiring up and testing. A multimeter will tell you which way around the existing wiring works and will allow you to complete the job.
If the LEDs are wired up in series then you will need to introduce a resistor before the first LED, or after the last one.
If you need any help with this let me know.
Tealc knows what he's talking about.
I taught him everything he knows
Or is that the other way round???
Seriously though, have a go. Remember everyone who knows how to do something at one point didn't have a clue themselves. In other words the only way to learn is to do it.
have either of you made switches for led fans to turn the leds on and off, i have looked at a few guides already and wondering if you have any more advice?
The orange mod above has wiring which is separate from the fan's wiring and I have a switch now installed between the molex that it connects with and the +ve wire.
All you need do is find the first LED in the circuit and wire a switch in somewhere on the +ve line. This spot is sometimes marked on the fan PCB.
An independent fan wiring loom is advantgeous because too often the LED v
brightness is affected by fan speed and it's easier to wire in a switch of your choosing.
A switch can also be wired in the -ve wire, all it needs to do is break the circuit.
Can someone please write me a detailed tutorial on their log if they're planning on changing led so people who don't know how can benefit on it
I've been thinking about writing a quick tutorial on this.
I've got a Xilence Redwing 120mm which I have already pre-drilled waiting for such a time where I can be bothered to actually get on and mount some LEDs in it. I had planned to make it today but had to work on my car instead and that took all day.
For this one I am going to mount 4 per side, for a total of 16 LEDs. Orange again (Thanks for the Orange bug goes to G-Dubs)
I will be running 4 LEDs in series 4 times around the circumference of the fan.
If you can be patient I will get this done over the next couple of days and will also put some of the theory in the tutorial so you can adapt for your own needs.
Thanks mate and I don't know if you still use your msn which is on your profile but I added you anyways.
Think the tutorial would be a great idea Tealc, you were certainly a great help to me. In fact fair to say wouldn't have even tried to do it witout your guidance and patience (sorry about the orange thing)
