If you're on o2 provided over BT's network, then it takes 3 days for the IP profile to raise.
If you're on o2 LLU then they don't have IP profiles. The speed matches the sync rate straight away. However the throughput you see isn't quite as high as the sync rate. For example I'm currently syncing at 18,652kbps which right now is giving me 1930KB/sec download speeds - this equates to 16mbit of throughput.
