advanced excel help
6 Mar 2008
Stoke area
Hi all,
I've just been made redundant from my position and have been replaced by an advanced team who basically know nothing.
As such, I have been asked to build a spread sheet that will allow them to write a shift report saying which employees are doing things at certain times.
I have so far figured out drop down lists so they just need to go in and select what jobs they are doing and where.
I then however would like to output this in to BB code format as we post the shift report on an internal forum.
Can this be done?
You could probably write some form of VBA script to process all the data into BBCode, might be pretty time consuming though.
well I've found this:
http://www.cpearson.com/excel/ImpText.aspx
it outputs to an TXT file, which to start with will work.
I've added a button to call the script however the problem I have is that no one has access to admin rights so can't save on to the PC directly, instead they have to save to their profile.
Of course each profile has a different address different and I have no idea how to change it to try and make it work :(
*unless I share it to the saved drive, hmmmm.
well, the script works and outputs to a folder on the shared drive.
Now I need to figure out how to ignore empty cells :S
You could always write it to a temporary worksheet.
Environ("USERPROFILE") should get you their c:\users\xx or c:\documents and settings\xx location no matter where it is.
