- 26 Apr 2004
- Milton Keynes
Acer Aspire Revo R3610 Dual Core, 2gb ram, 250gb hdd, Linux - £189.99
You can then get a 640gb 2.5" hdd for about £50
Thats a route Im considering, then installing Win7 on it and using DXVA with the Ion. I was going to use XBMC but it doesnt play all my files correctly, and Im a little concerned about the hardware being underpowered for slightly more complicated decoding setups once filters are applied and also running off the GPU, its only a 9300, and the CPUs not exactly potent enough to take up much slack
The OP has money for more powerful hardware, so fair play to him, the Revo is good, but has its limitations. Revo doesn't have a remote either which is a bit of a shame
