Advice for cooling down system
18 Oct 2005
I've just installed new gear in my antec P180 case. the case has 1 intake fan, 1 top exhaust fan, and I have the corsair h50 exhausting using push/pull. All fans are now apache blacks.
The system is quite hot though, gtx 280 in there and shortly a gts 250 will be going in for physc and the cpu is running quite hot on load.
My question is, what else can I do to cool things down? i cant fit another intake fan in, unless maybe i stack another apache black next to the current one? or is there a thicker fan (>25mm) i could put there. I only have 1 spare 5¼ drive bay, is there a row of small fans i could use to intake there? What about mounting some fans inside the case? how do people mount 120mm fans within the case, or what about some of these?
http://www.overclockers.co.uk/showproduct.php?prodid=SY-000-AN&groupid=701&catid=57&subcat=399
A lot of questions but i'm sure most of you will have some ideas.
thanks!
There's probably space for another intake fan at the front (I have the p182 with three front intakes, push-pull intake at the rear :( and one :o exhausting hot at the top. Totally unbalanced but temps aren't too bad.)
Don't think there is, theres only the one right at the bottom for the enclosed hard drive/psu bit, but i've had to remove the fan that used to be inbetween. so you're saying maybe keep the front one intaking, change the rear to intaking, and keep the top one exhausting? would want a dust filter on the back i think
On mine there's a space for an intake in front of the middle HDD bay (with dust filter), as well as the one right at the bottom.
Well I'm not saying it's necessarily the best solution, but it works for me at least :)
