Advice for CPU Loop
12 Mar 2012
Lincolnshire/ UK
Ok so I am looking to buy a Rad/Radiator and theres quite a bit of choice out there so was just looking for a little advice.
For now I only plan on cooling the CPU and am only looking for something that would work best to cool the CPU.
I do not really need a "incase you want to upgrade" but somthing purely optimal for the CPU.
I'll be using a
i7 2600k processor
xspc raystorm cpu block running on 3/8id hose
any advice would be greatly apreciated
thanks for your time reading this :)
How much do you want to spend?
How big can you have a radiator? Do you have space for 2x 120mm Fans next to eachother? If so then you can fit any Dual Radiator from the OCUK Section, it all depends on your budget, how much space do you have from the fans to your motherboard etc??
Im using the NSXT Phantom 410 case
has space in the top for a 240mm/30mm thick rad but from the looks of it I think I could fit 2xfans above and below that size guide too.
then of course theres always other ways to mount rads.
price wise im looking across the board as If theres one I really feel Id benifit from I would wait until payday to pay that bit extra
