Advice for game rig (and photo editing) £700 max
19 Sep 2013
just thought i would ask for some recommendations on a system to keep up with my sons who have i5 systems and would like it to be able to handle newish games (ARMA 3 ect.) but also need it for photo editing as i'm a keen photographer.
I dont need a SSD (have a new unused 240g )
dont need OS (got windows 7 pro)
i have a monitor so can make do with that if it keeps costs down and better components
£700 give or take £50 if necessary ..
Welcome :D
What monitor do you have? Also, do you need keyboard and mouse?
I believe Photoshop CS6 can make use of OpenCL, so an AMD card would be nice. Something quick I made if you didn't need keyboard/mouse
YOUR BASKET
1 x Gigabyte Z97X-SLI - Devils Canyon Core i5 4690K Bundle **£12 Saving** £277.98
1 x MSI Radeon R9 290 Gaming Edition 4096MB GDDR5 PCI-Express Graphics Card £227.99
1 x TeamGroup Vulcan RED 16GB (2x8GB) DDR3 PC3-19200C11 2400MHz Dual Channel Kit (TLRED316G2400HC11CDC01) £89.99
1 x Seasonic S12II 520W '80 Plus Bronze' Power Supply £52.99
1 x Toshiba (7K1000.D) 1TB SATA 6GB/s 32MB Cache - OEM (DT01ACA100) HDD £41.99
1 x Xigmatek Mach Midi-Tower Black £21.95
1 x Arctic F12 Case Fan - 120mm £3.98
Total : £726.47 (includes shipping : £8.00).
There's also the 290X which is a bit quicker for about £10 more
https://www.overclockers.co.uk/showproduct.php?prodid=GX-281-MS
Would you ever go for two video cards (crossfire/SLI?)
or with a cheaper motherboard
YOUR BASKET
1 x Intel Core i5-4690K 3.50GHz (Devil's Canyon) Socket LGA1150 Processor - Retail £199.99
1 x Gigabyte Z97P-D3 Intel Z97 (Socket 1150) DDR3 ATX Motherboard £63.95
Total : £712.43 (includes shipping : £8.00).
I believe Photoshop CS6 can make use of CUDA, so an AMD card would be nice.
LOL what? CUDA is an Nvidia technology not and AMD one:D
@OP,
Here is a great spec,
YOUR BASKET
1 x KFA2 GeForce GTX 970 OC Silent "Infin8 Black Edition" 4096MB GDDR5 PCI-Express Graphics Card **WorldWide Exclusive** £269.99
1 x TeamGroup Vulcan RED 8GB (2x4GB) DDR3 PC3-19200C11 2400MHz Dual Channel Kit (TLRED38G2400HC11CDC01) £44.99
1 x Antec VSP5000 Silenced Tower Case - Black £39.95
Total : £713.84 (includes shipping : ).
Nvidia card so you do get CUDA:D
Case with three fans with low+high speed controllers, no need to add any extra fans into the build.
my monitor is a bit old.. its fujitsu siemens 22" so would i benefit from getting a new monitor (had this one for a few years maybe 4)
i'm fine for a keyboard and mouse ... thanks for the quick response
That Antec case is great, and silenced too, perfect for any gaming and 3d/GFX work, will keep any GPU noise down for you.
keep the suggestions coming ..i'm off to work so will check back later and hopefully get the components ordered!!! ... how much is it to have it built?
You definitely want to go with AMD for OpenCL, and even in gaming the 290x is still a better proposition than the 970. The one for 300 that stulid posted is bonkers, you can easily get those games for 20 quid each.
If you're gonna pull the trigger this week then go for this GPU: https://www.overclockers.co.uk/showproduct.php?prodid=gx-281-ms&groupid=701&catid=56&subcat=1752
as for monitor, there's no question about it you have to get an ips panel for photo editing. Look here for some suggestions.
