advice for new water cooling noob
26 Nov 2017
hit guys i brought last year the defcon bundle rog maxiums x hero mobo and 18700k oc 5ghz
with the aio
well im water cooling with loop system and my zotac gtx 1080 ti
so things im after is where do i plug the water pump into and fans and how do i regulate the temp
everything else ive pretty much got covered
i read my user guid and it says it has a water pump header which gives me 3 amps 36 w full speed ?
on reading the aio pump header is 3 amps 12w
the pump i have has a working wattage of 4-10watts
please advice would be help full
cheers
Hi i prefer running pump of a lead like Molex and just run full but can run from board if has a dedicated pump header.
Using board header (not sure how yours is configured?)many power to pump can go up and down so regulates it that way!
Full on keeps it from increasing latent heat if pumps running slow.
Which loop/system did you get as looking back onit there was offered a few!
Or are you talking about a dedicated loop now? ifso what pump is it?
What size/make/name rads do you have
itsa custom loop from gpu byski ice dragon gpu block to cpu freezmod aly cpu block have 240 rad and the pump is a rai-pm5 from overclockers just not to sure yet what size pipe to run was going for 3/8x1/2 or 10mmx13mm flexi till i can aford a better case then was going to hard pipe it
Well not going to cool much with a 240mm rad! Alloy CPU block! mixed metals!
which rad is it?
