Advice for overclocking a gtx 580
28 Oct 2010
Colchester
Hi guys and Girls,
Need some help/advice, I want to overclocker my gtx 580 3gb but i have never overclocked a graphic card in my life!.
I will be using MSI afterburn to overclock my 580 but my question is what are the safe volts and what is the best way of testing the card to make sure its stable.
My 580 is custom watercooled, @ stock its idels at 25'c @ load 37'c, so temps i dont have to worry about as such.
Any help would be gr8,
Thanks
Sgt T
Sitting here wondering why you have a watercooled rig with no knowledge of overclocking.
However, I have same card, and I've been told several times that absolute max is 1.14 - 1.15 ish. I go no higher than 1.1, but that's because their phantom cards in sli and anything more than that is leaf blower territory.
Best way to test stability is to run loops of Heaven bench for 2-3 loops at a time. If it's unstable, there's a good chance it will crash out during the first loop.
i do have knowladge of overclocking my cpu as it is sitting at 4.8ghz @ 1.39v.
I've never overclocked a graphic card and i wanted some advice on how to make sure its stable and the max volts ;)..
Thanks
