Hi,
I've purchased the following:
http://www.overclockers.co.uk/showproduct.php?prodid=CC-004-SR
Along with an MX100 Crucial SSD.
The SSD will only be used as an additional drive for games, I already have a smaller SSD for the OS.
My motherboard is the P6T SE, which has SATA 2 and 3 PCIe 16x slots - 2 at 16x and 1 at 4x.
Manual here: http://dlcdnet.asus.com/pub/ASUS/mb/LGA1366/P6T_SE/E4481_P6T_SE_manual.zip
My problem is where to fit the PCIe card, I need to use the card as I don't have any more SATA slots on the motherboard.
I'm not sure I can fit the PCIe card in the 2nd PCIe 16x slot as I have a GTX670 in the first slot which takes up a lot of space. Even if I could fit it in then it will probably block the fan on the 670 - not advisable I guess!
So will it make any material difference in terms of performance to simply fit the PCIe card in the x4 slot?
Alternatively I can move a storage drive from the motherboard SATA 2 connections to the PCIe card (in the 4x slot) and put the new SSD on SATA 2.
Essentially my question is:
Which is the better option?
Thanks
Thanks
