Advice for two builds
26 Jul 2012
I'm looking for information on two builds.
The first has to be £500 (can't be over).
The second needs to around £400, but there is wiggle room for up to around £450.
Both builds need everyone except for monitors, keyboards, speakers and mice.
Thanks
:) - What will these 2 builds be for? Gaming, general browsing?
The lower priced one will be for general use, however they'd like to be able to play movies in 1080p smoothly.
The higher priced one is really the same but they'd like to be able to play Battlefield IV. If that is at all possible on this budget.
For the gaming one.
YOUR BASKET
1 x VTX3D HD 7850 X-Edition 2048MB GDDR5 PCI-Express Graphics Card £119.99
1 x AMD Piledriver FX-6 Six Core 6300 Black Edition 3.50GHz (Socket AM3+) Processor - Retail £89.99
1 x Microsoft Windows 8.1 64-Bit DVD - OEM (WN7-00614) £71.99
1 x Gigabyte 970A-DS3P AMD 970A (Socket AM3+) DDR3 Motherboard £59.99
1 x Seagate Barracuda 7200RPM 1TB SATA 6Gb/s 64MB Cache - OEM (ST1000DM003) HDD £43.99
1 x BeQuiet Pure Power L8 400W '80 Plus Bronze' Power Supply - With 120mm Silent Wing Fan Built in £39.95
1 x BitFenix Merc Alpha Gaming Case - Black £32.99
1 x TeamGroup Elite 4GB (2x2GB) DDR3 PC3-12800C11 1600MHz Dual Channel Kit (TED34GM1600HC11DC01) £32.99
1 x OcUK 24x DVD±RW SATA ReWriter (Black) - OEM £14.99
Total : £520.96 (includes shipping : £11.75).
And the other
YOUR BASKET
1 x AMD A8-5600K Black Edition 3.60GHz (Socket FM2) APU Trinity Quad Core Processor (AD560KWOHJBOX) £71.99
1 x Sapphire PURE Platinum A85XT AMD A85X Chipset (Socket FM2) DDR3 ATX Motherboard £68.99
1 x TeamGroup Elite Black 8GB (2x4GB) DDR3 PC3-12800C11 1600MHz Dual Channel Kit (TED38GM1600HC11DC01) £59.99
1 x Kingston 60GB SSDNow V300 Drive SATA 6Gb/s 3 2.5" (7mm height) Solid State Hard Drive - (SV300S37A/60G) £47.99
1 x **B Grade** Seagate Barracuda 7200.12 500GB SATA 6Gb/s 16MB Cache - OEM (HD-252-SE) £30
Total : £481.97 (includes shipping : £11.75).
Are both builds for the same person? If so, then you would be better off having a total budget of £900 - £950 for 2 builds and spending maybe £600 on the gaming one and £350 on the other. This would obviously change the 2 builds quite a bit. As you can see the gaming one above only has 4gb of RAM where as the other has 8gb. You could swap them round and the total cost would remain the same. Does that make sense?
I also put a blu ray drive in the second one but I'm not sure if there's a need for it? Do they watch films off discs or downloaded ones?
