advice/help needed
2 Jul 2007
orthos an super pi both "encounter a problem" intermittently when i'm using them with vista 64 ultimate.
also orthos reads my overclock at close to 4ghz when its actually 3.5ghz. :confused:
has anybody had similar problems with the same OS using these 2 programs?
cheers for a reply :)
if your not using the default cpu multiplier orthos will read it incorrectly. what kinda problems you getting with SuperPi?
both programs, windows shuts them down "super pi has stopped working"
sometimes while its running a calc.
on orthos when your just selecting options, eg selecting which test or priority and occasionally when a test is running, same thing, "orthos has stopped working"
details: Problem Event Name: APPCRASH.
systems running smooth apart from this.
what ya reckon?
is their other programs that i can use that work with vista64?
