[Advice] Need to Fix Problem with 4 Computers
9 Dec 2006
@ManCave
Hi all,
Need ideas on what to do to fix these problems were having at work.
We have 60 Servers at work with the below config.
Problem were getting is 4 Servers of the 60 are freezing/locking up.
Mouse doesnt move Keyboards doesnt work (num light is on)
Time is frozen also. No Memorydumps even though there ON.
I fixed these 4 Servers before and they were running for 2 weeks no problem.(they previously crashed in 2 days)
I fixed them by Doing a Clean install of 286.28 Nvidia drivers.
We recently had a powercut & now there doing it again :( The fix no longer works. i have one running Memtest86 one running Disk Error Check & 1 of the four appears to be running ok.
Spec of all Servers:
i5 2600k
ASUS (i can get model number if required)
Cosair 4GB Ram 1066mhz
1TB HDD Samsung F3
460GTX
2 x AV Cards
500W Silverstone PSU (from what i remember might be higher)
Windows 7 32Bit (yes i know, 64bit soon)
Have you checked the event viewer? If you've had a powercut I'd want to check the integrity of the disks (and look into buying a UPS)
What are these servers doing out of curiosity? Because they don't look server spec.
Event Viewer - Says nothing worth while.
Disk - Doing that already.
UPS - No need not required up 80% of the time.
Each Server run's 16 Live Videos with Audio & displayed the PC Which can also be accesed via IP.
This why we have a 460GTS(wrong in orignal post) to run the videos & Do some video anaysis using CPU/CUDA
A UPS does more than merely allow uptime (or rather safe shutdown) in event of a power failure, it provides clean electricity and helps guards against spikes, something I want on my home PCs, let alone servers.
They aren't really what I would call servers in a work / corporate environment. They are custom built machines with no support right? Consequently when things like this happen it could be a lot of different things. UPS as mentioned is a good idea for the future but for now.... what is different about these 4 compared to the other 56 then? Different location? Slightly different hardware? Running hotter? Different software? Different BIOS? Has to be something that is different surely?
