Surely the AIO at the front would dump even more hot air onto the GPUs and VRMs? Sure the CPU itself would be better, but everything else would get hotter.
The bottom left 3rd of your system looks almost completely isolated from airflow, with little space to let any air out. Can you put the hard drive tray at the top? It may seem daft, but it's the GPUs that are pumping out most the heat, so need the cool air circulating, the hard drives at the top would block flow there too, but it may allow for a better flow overall, going from bottom right to top lef, rather than top right to top left at the moment.
Then if you can get/fit a little 90mm fan at the bottom against the empty PCI slots, you could perhaps try and get more exhaust going there. Maybe try moving the system further away from that back wall too, allow the air to escape a bit more easily (probably not an issue, but may help).
Ideally front is better. Maybe the OP get a different case. The vrms and graphics card would suffer far less than the cpu they would be fine, its a 240mm aio if OP got a different case the 240mm goes up top and then a fan underneath I'm sure you can do that with a different case.
https://www.youtube.com/watch?v=xNAMxZgvves
Are front mounted radiators bad for your PC?
https://www.youtube.com/watch?v=YCZ5iP5cu8g
