advice needed for my first WC machine
4 Oct 2012
Hi everyone
So i am thinking of doing this water cooled machine but since it is my first one i am kind of a noob here hehe
So far i have a few things picked out but since i have not done this before i dont know how to make sure everything will go together and if it will fit my case.
This is what i have so far:
Swiftech Apogee HD
swiftech MCRx20-XP "eXtreme Performance" Radiator Series(1x120mm on the back and 1x240mm on the top)
Bitspower BitsPower Z-Multi 150mm Water Tank
Swiftech MCP655 pump
Case-Corsair graphite 600T
This is my PC :
Intel core i7 2600k
Geforce GTX 590
Asus maximus IV Extreme
8GB Ripjaws RAM
HDd 750GB + SSD 124
I want do do a loop from my for my CPU and GTX 590.Only that will be liquid cooled.
Only the CPU is overclocked at 4.7 GHz
If any of you have any suggestions for fans,liquid and anything else please share!
Also if u guys think i should change some parts for better ones please share aswell
I can only put so many rads in my case because there is no more room.
Also will it be worth it to make it push pull?If yes why and if not why?
Put a square 200mm rad in the front. Also I have a 360 in the top of my 600t - just a small amount of cutting required.
Both is probably best. My 360 just about keeps my 7950s cool, but I am going to add either a 200 in the front or a giant external rad before adding the CPU in. And your 590 is probably hotter than my 7950s.
