8 May 2010 at 17:40 #21 will13 will13 Soldato Joined 4 Jul 2009 Posts 3,246 Location Kilham, East Yorks makamiso said: the antec 1200 will hold a 5870 right? Click to expand... Should do, Ive still got quiet abit of room in my 902 (yes I know the 5870 is bigger then my 5850), and the 1200 is even bigger..
8 May 2010 at 18:20 #22 makamiso makamiso Associate Joined 15 Nov 2009 Posts 465 Location Bristol well ive got a good amount of room before my 5850 hits one of the compartments on the 1200 and if needs be you can pull them out a bit.
10 May 2010 at 12:59 #23 regulus regulus Soldato OP Joined 18 Aug 2006 Posts 10,053 Location ChCh, NZ the 922 just appeared. She's a rather big girl. Just hoping the 5870 fits in now :s
10 May 2010 at 13:26 #24 Ph4lanx Ph4lanx Associate Joined 19 Apr 2010 Posts 474 Location Surrey MonkeykingZX said: my original cm 690 fits a 5970, it took a bit of wiggling to get it in there so don't give up hope edit: oh yeah +1 for the cm 690 II (or even an original cm 690 it's only £60.99 ) Click to expand... The CM690-II is smaller inside mate than the original.
