- 31 Aug 2020
Hi,
I'm new to PC gaming and have always used consoles. With the new PS5 coming out soon, I'm thinking an option would be to upgrade the PC I currently have instead of buying the console.
This will be used for Call Of Duty Warzone predominantly, so would like it to run this comfortably.
I don't have a specific budget, don't want low end parts that just about do the job, but also no need in spending a fortune, it needs be a big enough difference compared to the new console coming out to warrant going ahead.
If I was to put the current spec of the PC I have, would anyone be able to tell me what could be kept, if anything. Also what would need replacing or adding? I built this PC new 2 years ago if that helps.
Current Spec:
Graphics (GPU): AMD Radeon RX Vega 11
Processor (CPU): AMD Ryzen 5 2400G 4 Core
RAM: Corsair Vengeance LPX 8GB
Motherboard: Asus Prime B350M-A
Power supply: Corsair CX750M
Hard drive: 1TB Crucial MX500 SSD
I have downloaded warzone onto the current PC and it says not enough VRAM to run the game.
I have tried to explain as much as possible in this post and if anyone requires more please let me know.
Thanks
Current Spec:
Thanks
