Hi folks
So, I'm having a bit of a nightmare and I need your help...
Basically, I've recently set up a NAS, and have been consolidating my documents and photos onto it. I took the cautious approach, and copied to the NAS, then, only when I'd confirmed the copy had been successful, I deleted from the source.
The NAS is set up as a RAID1 storage pool. 2x 2TB drives. File system ext4.
Today I decided to attach my external USB drive to the NAS, to transfer some photos. This is where the problems started. Ever wish you could rewind time?
So, I connected the USB drive, and set a task for it to copy the contents to the NAS, giving the destination as as subfolder of a folder named Photos. However, what seems to have happened is that the USB drive was in some way unreadable, and the NAS has mirrored the non-existant contents of the USB drive to the Photos folder. This has resulted in deletion of everything within that folder. It's now an empty folder.
Knowing a little bit from previous experience with file deletion, what I've done is immediately removed one of the drives, and stopped using the NAS completely. Therefore, I have (I'm hoping) a drive in the state immediately post-deletion.
What can I do, if anything? I've just been Googling, and have come across extundelete, but I have to be honest and say I don't really understand it, and it's Linux from what I can tell.
Any suggestions will be most gratefully received!
