I'm fairly sure you need less head pressure to pump a given mass flow rate through two blocks in parallel than to pump through a single block, probably as 1/Rt = 1/R1 + 1/R2 since electrical/water analogies mostly work.
If your system initially pumps m kg/s through a single cpu block and you add a second in series, you'll get less than m flow rate. If you add a second cpu block in parallel instead, you'll get more than m flow rate in total, but still less than m through each individual block.
The answer to optimising n pumps through m blocks inevitably lies in performance curves and maths, but without running the numbers I don't think the everyhing-in-series rule of thumb can be trusted.
