Hi to you all,
advice needed with buying a SSD drive !
Would like to buy 128gb model,been looking at the following ;
1.G.Skill Falcon 128GB
2.OCZ Vertex Series 120GB
3.Corsair Extreme X128 128GB
I under stand that option 1 & 2 are the same thing
which 1 will be better supported with firmware updates
which 1 will be the better option for windows 7
which 1 jas the best performance
Many Thanks
Paul
Many Thanks
Paul
