Advice o/c using XFX750i
4 Mar 2008
Having some problems o/c using the spec in the signature below. I cant get a stable o'c at say 3.333GHz which is would have thought been quite achievable. My CPU voltage is 1.375, NB is 1.45 and FSB is 1.5. RAM is 2.0 with the timings set to auto. Speedfan says my temps are 35,29,31,30 across the cores at idle. The system will apear stable but after a short bout of gaming, the system resets. This also happened when I had a GTX275 so I dont think its the 5870 below doing it.
Can anyone help with getting a stable o/c
Cheers :D
