Advice on £250 spec
18 Oct 2002
Fife, Scotland
Looking around the OCuk shop ive selected the following components and im after a little bit of advice...
Intel Pentium Dual-Core E5200 "LGA775 Core 2" 2.50GHz (800FSB)
OCZ Platinum Revision 2 XTC 2GB (2x1GB) PC2-6400C4
Asrock 4CoreDual-SATA2 Rev2 (Socket 775) PCI-Express/AGP DDR2 Motherboard
Corsair VX 450W ATX Power Supply
Budget is £250 and im wondering about what graphics card to add to this shopping cart... Or if there is a decent Onboard option.
Any other ideas for this spec are welcome as ill be ordering soon...
Product Name Qty Price Line Total
Gigabyte GA-MA770-UD3 AMD 770 (Socket AM2+) PCI-Express DDR2 Motherboard £67.84
(£58.99) £67.84
(£58.99)
Asus ATI Radeon HD 4670 512MB GDDR3 TV-Out/Dual DVI/HDMI (PCI-Express) - Retail (90-C1CLP0-J0UAN00Z) £60.94
(£52.99) £60.94
(£52.99)
AMD Athlon 64 X2 Dual Core 7750+ Black Edition 2.70GHz (Socket AM2+) - Retail £57.49
(£49.99) £57.49
(£49.99)
OCZ StealthXStream 500w Silent ATX2 Power Supply £44.99
(£39.12) £44.99
(£39.12)
OcUK 4GB (2x2GB) PC2-6400C5 800MHz DDR2 Dual Channel Kit £28.74
(£24.99) £28.74
(£24.99) Sub Total : £226.08 Shipping cost assumes delivery to UK Mainland with:
DPD Next Day Parcel
(This can be changed during checkout) Shipping : Free VAT is being charged at 15% VAT : £35.41 Total : £261.49
Thanks for the replies and the spec :)
The PC is just for very light gaming, its main use is media, watching HD content etc.
Also my friend has only Windows XP 32bit so 4GB isnt really a requirement. I should also point out that he has IDE harddrives which he wants to use, so a motherboard with 2 IDE ports is needed :(
I'll check out that spec, would it be better than the intel alternative?
Cheers
Thanks a lot for the reply mate,
I checked the motherboard out and its shown as only having one IDE port :(
