Hi, before you call me a rich mofo I've been saving for 10 years for this, currently running a Core i7 920 @3.2 GHz and the only thing I've upgraded since buying my rig 10 years ago has been the GPU (GTX 670 upgraded from GTX 285).
So I have 3k + VAT (i.e. £3.8k inc VAT) to spend and the goal is to use this rig for sound production and gaming.
Currently this is what I'm thinking:
Any other suggestions? NVMe? Intel Optane memory? Any overkills? Anything that can be improved upon?
Thanks in advance
- Intel® Core™ i9-9900K processor = £599 - More cores, more power. All welcome for both sound production where I do a lot of CPU intensive work using multiple cores, and gaming.
- Gigabyte Z390 Designare = £230 - Good for overclocking, has 2 Thunderbolt 3 inputs which are needed for my audio equipment (audio interface + expansions)
- Corsair Hydro Series™ H150i PRO RGB 360mm Liquid CPU Cooler = £137 - As I'm planning to overclock the CPU to 5.0 GHz I thought I'd need this cooler. Is this an overkill? Can go for something cheaper instead?
- Corsair VENGEANCE® LPX 16GB (2 x 8GB) DDR4 DRAM 4266MHz C19 Memory Kit = £127 - Not interested in LED, I think 32GB would be an overkill for what I use my PC for. My current PC has 8GB and I'm doing just fine memory wise.
- Samsung 860 EVO SSD 500GB SATA III 2.5 inch 500GB = £68 - Good bang for buck in my opinion, any point in going NVMe considering the prices go up exponentially with no sizeable returns?
- WD BLACK Performance Desktop Hard Drive 6TB = £218 - Generally have had very good experiences with WD Blacks but I need a lot of storage for my audio files which take a lot of space...and there is many of them, hence why 6TB.
- Gigabyte GeForce® RTX 2080 Ti WINDFORCE OC 11G = £1300 - Frankly think RTX series are way too expensive for what they are but why the hell not. This is my treat to myself after a decade.
- Corsair Obsidian Series™ 750D Full Tower ATX Case = £122 - I've built quite a few systems over the years on this chassis and it is a fantastic case. Full tower giving a lot of room and airflow and it doesn't look too game-y and very easy to work with. My only gripe with it is that it doesn't have front USB-C inputs but I guess I can live with it. I'm open to suggestions.
- Corsair HXi Series™ HX750i High-Performance ATX Power Supply — 750 Watt 80 Plus® PLATINUM Certified PSU = £128 - Really nice modular PSU I've had the pleasure of working with a few times. Hope 750W is enough for my build?
- I'm thinking either a Samsung 32" CHG70 Curved High Resolution Gaming Monitor or a Samsung 2018 49" Q6F QLED 4K Ultra HD certified HDR 1000 Smart TV - I have around £900 to spend on the screen. I will be plugging in my consoles to it as well and not a big fan of ultra-wide screens. I'm not an expert when it comes to screens so open to suggestions here.
Thanks in advance
