advice on bedroom idea
17 Dec 2009
Bedroom idea with digital print
been playing around with revit abit and got an idea to design on my bedroom. Im goig to buy some inkjet wallpaper to print on, and print an image onto my bedroom wall, then give the other walls a colour wash effect of a colour that matches the image.
all design is to scale from items to walls, i've decided on the wall i want to do this on, which is one that ive had to knock through, so my initial drawings are actually wrong now, as there is a recess where the picture ends near the door and its not straight like the drawing, the the picture shall only go so far like so:
obviously colour scheme would change depending on drawing.
I first went abit mad and designed pretty much every wall to have printable wallpaper, but after working out costs and materials i thought it would be abit silly to actually go ahead and do this.. So i opted then to just do the one wall. Heres my inital crazy idea
anyways, ive came up with a few photos but unsure which one would look good. I could even maybe switch walls to the one with the wardrobe if it meant most the image was focused on the right hand side s its not blocked by the wardrobe
http://s168.photobucket.com/user/spunkydamonkey/library/room?sort=3&page=1
any help or new ideas appreciated
well ive been downloading images that are of 4000x4000 or above in hopes the image will be large enough. ive been using earthporn and spaceporn for high res images.
i guess its not to everyones taste, i just wanted to be different but now im trying to choose i dont know if it is a good idea, but my minds been set on doing it for weeks its too far to go back :D
i suck at revit :p
it took me a day of headaches just to work out how to draw the room, colour the walls and add a picture to the wall.. all the items and stuff i did in inventor and imported in, i thought revit would be easier than it is :p
I'd say those pics won't be anywhere near big enough to give you decent image quality at wall type sizes!!!
Most printing presses etc recommend artwork be at 300dpi which will give a good quality print. At that resolution your pics will be about 33cm square! if you were to print at 150dpi you'll be looking at 67cm square. For the sort of size you're looking at, say 2m x 2m the print resolution will be approximately 50dpi, which will not look great!
It might be ok to look at from a distance but up close as you would be in the room it won't look nice!!
Get it professionally printed and hung.
No really, most seasoned decorators would struggle to hang huge custom picture paper like that and get it perfect.
Not to mention even if you had A3 you'd have way too many seams for it to look good, not to mention you're asking for colour bleed and tearing problems. Better to get a pro wallpaper printer to do it.
Who said i was using A3?
My dad has about 4 different types of printer with different inks in each from sublimation to canvas, some go as large as 50" width rolls, which the wallpaper ill be using only needs a 24" printer anyways. and my Sisters Husband is a professional decorator, not that it would matter, as I doubt most decorators will have experience in putting up large image wallpaper! But I'll have seasoned help with all aspects :p
http://getcanvasplus.co.uk/inkjet-printing-wallpaper.html
Just blew a few photos up to scale and yes, they are a tad poor quality :(
the one I had my eye on was
http://i.imgur.com/Oqe4J7r.jpg
in regards to that website, it says
A good guideline is that the image must have at least 1 pixel for every millimetre of the wall mural. For example, if you want wall mural 400 x 250 cm (or 4000 x 2500 cm) in size, your image should be at least 4000 x 2500 pixels (10 megapixels).
my room is 320 x 240 cm
Sounded like you were buying into some crappy "can hang like wallpaper" con stuff. You didn't mention your dad had fancy kit! :p
300DPI is recommended for photos viewed at arms length.
My photo wallpaper (link above) looks grainy when standing close but looks great 1-2 feet away.
haha, i wouldnt be trying it on a cheap office printer not a chance :P
the ink alone will cost the money but we get it cheap enough
I was always going to think id get some distortion with the image as on a wall scale its only natural
Ive decided I cannot find a great sunset/sunrise/orange skyline so Ive created my own with filters and a decent 14mb (5616 x 3744)
Can someone give me a hand in choosing which is the best/not too overkill
original
30 opacity
45 opacity
65 opacity
80 opacity
room layout change
just a little update on my progress..
had a nightmare from start to finish. fresh wall in place, plastered, painted as well as rest of room. fresh skirting boards, but for the last 3 days ive been trying to get printer to work as light magenta was acting up. a service tonight has got it running smooth, but unfortunately at a price of wasting too much paper.
I now have to lash a further £45 for a new roll, but will have 15 metres left spare so could always do another wall elsewhere. the cost will probably be around the £100 mark with 16 metres left and used ink, which isnt bad.
Heres a few pics of the first roll and overall image
Hard to tell when you keep using a potato to take pictures with, but I guess that looks OK.
A bit like looking at someone's house from inside your house?
I'm hoping someone might do a woodland scene.
Actually as you have the kit, you could start selling the idea to others?
