Advice on changes to build
2 Jul 2013
Derbyshire
Hi all,
I configured and ordered my computer last Friday and scrounged a few more pennies to spend (£75). Below is my current build, but I plan on calling up and making some changes.
YOUR BASKET
1 x "Intel i3 Ivy Raid" Intel Core i3 3220 Ivybridge Dual Core Gaming System £239.02
- 1 x Microsoft Windows 7 Home Premium SP1 64-Bit - OEM (GFC-02050) £83.99
- 1 x Kingston HyperX Genesis Grey 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (KHX1600C9D3X2K2/8GX) £59.99
- 1 x 24 MONTH WARRANTY - COLLECT & RETURN £0.01
- 1 x Standard Build Systems - Approximately 5-7 working days £0.00
- 1 x Intel 330 Series 60GB 2.5" SATA 6Gb/s Solid State Hard Drive - Retail £73.99
- 1 x Seagate Barracuda 7200RPM 1TB SATA 6Gb/s 64MB Cache - OEM (ST1000DM003) HDD £49.99
- 1 x KFA2 GeForce GTX 650Ti Boost 2048MB GDDR5 PCI-Express Graphics Card £139.99
Total : £665.58 (includes shipping : £15.50).
If anyone would like to suggest what changes I should make it would be highly appreciated! My thoughts were to change something like the fan or the sound as it was not an to option to change when configuring...
My memory is already 8GB?
But thanks for the suggestions I'll look into the two more when I'm off my phone
Even cheaper upgrade then. :D
It`s just a shame you can`t upgrade the mobo to a Z77, that way you could then upgrade to an i5 when your funds allow. The only H67 mobo OCUK do, is the Foxconn.
The Gpu I specced, can be OCed to 7950 stock speeds, making it really good value.
Indeed! :) at most I could go an extra £100
Idlemans build is much better but as he ordered the pc last Friday is he able to cancel?
I missed that bit, bugger. :D
I suppose it depends on the delivery date. He should have posted earlier today. Best to wait on the OP now, to find out when it is actually being delivered.
Yeah I don't think I'll ever give building a PC a go myself. I'm not easily convinced and prefer the much easier way of just getting someone else to do it at my own expense... but yeah I will try the graphics card and the fan tomorrow if I can get through in time on my work break!
